I have a 86 GMC Caballero 305 that has just developed engine run on for the last couple of weeks. I have a new Rodchester 700 cfm OEM carburetor that's two months old, Idle speed is set to about 650-700 in drive, about 1000 rpm in park. Idle mixture is set to 3 full turns. I have replaced spark plugs, gaped em at .45 ..replaced with new wire set, new cap and rotor. I thought it was carbon build up, put one full can of Sea Foam in the tank with fresh full tank of fuel and bought another can for pouring down the carburetor at high idle to break up the carbon. I feel I have removed any carbon build up. My car is not overheating, just had the radiator cored and cleaned out, new thermostat 160 degree. The Caballero only runs on when engine is hot, about 190 degrees. My timing seems to be fine the car runs great and has plenty of power, just this dieseling has me baffled. Any ideas out there?
Update!
Starting to think it's winter gas mixture, I've checked everything else. Anybody out there experiencing problems with winter formula fuel?
Update!
