double hump crossmember help
redneckracer305
204
37
new milford,ct
ive been lookin for an after market dual exhaust crossmember for my cutlass supreme. what makes the cutlass supreme chassis different from other g bodys so the jegs and summit crossmembers wont fit
There should not be a difference in the frame on a Cutlass. Did you try calling them to see why they think there is a difference? If they don't have a good answer, order one and try it. You can always send it back.
The only difference that I am aware of in the frames is that the 78- either 81 or 83 cars have a slightly different frame on the drivers side where the crossmember mounts than the 84 and later cars. Some of the aftermarket cross members sell a frame extension so you can install them on the earlier cars.
Try the G-Force Cross Member. Their site does not say anything about excluding Cutlasses. I just put one in my car. It is nicely made and very heavy duty. The down side is that I believe it costs more than what Jegs and Summit sell.
[url=http://www.transmissioncente...w.transmissioncenter.net/gforc ... QQodvF7GQQ[/url]
there is no difference its all bullshit... the Jegster member will fit with no problem..
thank you very much for reyling cause man ive been hemming and hawing over it for a while cause i know the gforce one would work cause i know other people that have used it, but i wasnt sure if the jegster had some wierd difference in it or somthin, so thanks again. i think im gonna go for the 700r4 swap as my th350 transmission is kinda beat, and i got a nice 700r4 that was in my old camaro that was stock as far as i know and used to chirp the tires behind a stock tpi 305
oh plus i can get rid of my whooped rotted out cheapo glass packs that drag on the ground , and gain san overdrive gear for the highway
LOL what ever works man! Jegster also makes a Th700 r4 member as well..i believe its 10 more bucks over the Th350 member.
Why don't you save yourself some money and make your own out of the stock crossmember. I did and it works fine. Here is a couple of web sites that helped me do mine.
http://www.angelfire.com/80s/monte/crossmember.htm
http://www.angelfire.com/80s/monte/transmis.htm
http://www.maliburacing.com/dual_crossmember_mod.htm
id prefer not to make my own just for the fact that, i aint any good at welding, my brother is it aint worth the downtime itll take for him to get around to it,plus the aftermarket crossmembers look a little cleaner
summit's crossmember is supposed to fit all G-bodies, and if you have an earlier G-body, they also sell a frame rail extension kit. If you look in their recent catalog, the double hump crossmember is on page 222, and the pre-84 frame extentions are right below it. Summit makes no distinction between models of G-body. Th-350 crossmember number is: SUM-770300, and the fit all frame extention is SUM-770307.
