Drivers Door Pins Fixed - Window Messed up?
GP4U2NV
194
-1
Cincinnati
www.sidefx.org
So, my 83 regal. I did new pins, bushings and spring. The door orginaly only dropped 1/4 inch or so.
But, now when I shut the door the drivers door glass catchs on the on upper guide by the windshield.
How do I fix it?
You'll have to remove the inside door trim panels, to access the inside of the door. If you look inside, you'll see that there are several adjustments possible on the wndow track assemblies. Hard to describe, but you should be able to see what I'm talking about, once you get the trim panels off. Good luck.
Kirban sells a book on how to adjust G body door glass. The book is alot of help if you never adjusted the door windows before.
