driveshaft length questions for a 8.5
442force
41
i want to know what drive shaft will work for a chevy350/th350/8.5 ten bolt
i have my stock 307/200r4/8,5 shaft will that work? or do i need somthing else
simple thanks alot
th350 (6" tail) and 200-4r are the same length and use the same shaft. You usually only run into issues when you go 7.5 to 8.5 differential or run a transmission of an over all different length .... the attached document shows trans sizes. Curiousity has the better of me .... has the 200-4r failed? It's most likely a uni-bell and would fit your SBC with no issues. You'd probably be ALOT happier with it than a 3 speed.
simple thanks alot
Your stock driveshaft will bolt right in.
Some fresh U-joints might be a good idea while it's out.
thanks soo much guys.
the 200r4 well it was blown up big time cracked drum from a tard nuetral dropping it before selling it not me.
its mostly a strip car anyways
