i need help on finding the proper length for a drive shaft on a 86 cutlass with a th400 32 spline behind a 6.6 and 8.5 rear.
im not wanting to cut the original shaft. will an 85 delta88 mount to the rear and be as big around as the original...
theres also a th400 yoke that i found are they the same u joints as a gbody shaft and delta88 shaft
thank you
thank you
