Electric choke power
john87442
351
440
55
Geneva ohio
Ok so I’ve been searching the forum for past conversations on this and there was many, however I didn’t see any that stated where to get power on your fuse block for an electric choke.(maybe I’ve missed it).
I can’t put power on to check power with key on, everything is not run yet.
I removed the computer for the build and have a holly carb that needs power to an electric choke. I would prefer getting it from the fuse panel however not sure where to grab it from.
Any help is greatly appreciated.
There's a brown or brown/white wire coming off the C100 firewall connector that's piped to a fuse just for the choke.
Ok I’ll have to research that one more, I know there is a brown one for the alternator and a different one for the hood light, what fuse spot is it in on the block?
I read some guys hook it off the oil psi switch etc, but I really would rather use the dedicated spot just not familiar enough. Thanks
That fuse puts power to the oil switch which in turn feeds the dash idiot light and the choke. Click the link I linked in that last post.
