Electric conversion
Lue
868
46
Los Angeles, california
I have a stock non elctric 78 Malibu, and i want to convert so power doors and electric windows. Has anyone done this to there G-Body, and have any tips?
I also came across a couple 2dr G-Bodies at junk yard, does anyone know what i would have to take?
Well, you need several things. They are as follows: Both door wiring harnesses ( and their attached boots), the power windows/locks harness from behind the dash ( remove dash to get to it), the relays in the passenger's side kick panel with any brackets, window motors and regulators,2 lock actuators, 2 power lock switches and the 2 window switches. You will also need the circuit breaker for the fuse box and the proper linkage rod and retaining clips for the lock actuators.
For the record, I swapped the doors from 2 other cars onto mine and added the power locks at that time. My car had power windows factory, but I had to switch all of the wiring under the dash to make them work, so I have done it. The door harnesses are a 2 part affair, btw, with the window harness being taped to the rubber dust boot from the factory and the lock harness going through but not attached to the boot.
reply
Ok, thanks for the hint. I knew about the wire harnest for the doors but didnt know about under the dash relays and other goddies. I seen an electrical wire harnest for power doors and locks on ebay go for about $50. I think thats over price sense i come across a lot of pwr 2dr G-bodies @ the junk yard.....
