electric fan kits ready.....
H2O gbodies
May 2, 2009
96
6
8
If anybody needs a relay kit for running any of the following:
LT1/LS1 dual fans
Mark VIII fan
Tuarus fan
Ramcharger dual fans
....or any other style of fan, I have a kit for every possible combination for multiple speeds, dual speeds, AC over-ride, manual over-ride, etc. I build these to suit and while each kit caters to a specific style of fan(s), I can custom tailor the leads or routing and/or method of activation to suit your build/need. All of my kits are J1128 spec wiring and all connections are heatshrinked/soldered for the best possible connections. I also wrap the wiring in a heat/scuff resistant fiberglass braiding where available. PM me with inquiries and I can help you out and provide some pics so you get an idea of what I have to offer. My orders right now are running a 1 week leadtime for custom built kits and I have a nice stock of standard build kits right now. I also keep in stock hard to find stuff like various heat range temp switches-pigtail leads for them too, HD relays of every possible amperage rating as well as relay socket connectors, etc.
I ordered one of these harnesses from Jabin about two months ago for my Mark Viii fan and I was impressed with the workmanship and diagram was very easy to follow...I reccomend him.
New to my inventory of fan relay kits is my new dual speed harness for LT1 dual fans-that's right, dual speed from both fans! I include both low and high temp switches too if needed! PM me if you are running any style of dual fans and want a multiple speed harness for them!
Not sure off hand what the cfm rating is.....are you inquiring whether a harness can be made for them? Asnwer is yes but I would need to know if they are single or.dual speed....pm me for details on finding out how to tell...might need a close up pic of the fan pigtail.
Just to put this out there, I am offering the RamCharger dual fan harnesses for $129.99. This gives you dual speeds from both fans as well as an AC and/or manual AC override option and both low and high temp switches-approx. 215/205 and 195/180. I'll be adding them soon to my store site but thought i would let you guys in on the price ahead of time.
I also have Mark VIII kits for giving you three speeds for the fan which uses two temp switches and an AC override for 100% fan speed.
It's the only relay kit of its kind you'll find anywhere....this style of harness will convert ANY fan single or dual to a 3-speed fan or fans.
PM for details or check them out at therelaycenter.com
Where do you get your temp switches from and what are the On / Off temperatures?
I cross reference various parts store lines like BW, Wells and AC Delco-the ones I keep in stock for use with my harness kits are 228/220 for medium and 212/202 for low and the override high speed is triggered by AC use and/or by a manual toggle switch.
Lower temps are achieved using Hypertech switches by I prefer to run them at 200F or so. If you want lower on/off temps thatn that, you're better off buying your own switches from Jegs or Summit. I only include switches by request and it isn't required to use with my harness kits.
Typically, if your cooling system is efficient, medium speed is rarely triggered IF you are using a HO fan.
