Houston, we have a problem...
My son and I are working on reviving his 1983 El Camino. The car has been sitting in a garage for 20 years, so there are lots of old car problems to work through. Today's chore was to change the bulbs on a couple of non functioning lights. When we tested all of the lights about three weeks ago, the right rear side marker light and the right front marker/turn signal light did work. Everything else seemed to be fine. Headlights, taillights, brake lights, brake lights all worked. I started today by changing the bulb in the right rear side marker light. A new bulb fixed that one. In the process, I noticed a suitcase connector on one of the taillight wires. It is a dark green wire. I'm pretty sure that wire powers the right turn signal lamp. The suitcase connector was left over from an old trailer wiring mess that is long since gone. So, I decided I would remove the connector and clean up that wire. The connector left behind a cut in the insulation (that's how suitcase connectors work), so I snipped the wire, added a barrel connector and heat shrink.
This is where things got weird. Now that the wire is back together, the right turn signals don't blink. They stay on solid. The left turn signal blinks correctly, but the right one stays on solid. While troubleshooting this new problem, we noticed something else that is very weird. When my son pulled the headlights on, with the ignition off, the right turn signals come on solid. That's strange because there should be no power to the turn signals with the ignition off. What's even weirder is that when he engaged the right turn signal, with the ignition still off, the electric fuel pump energized.
To me, this screams out, "short circuit", but I don't know where to start looking. Where in the maze of factory wiring would the right turn signal circuit, the running lights, and keyed 12v be tied together? Could it be the ignition switch? Maybe the headlight switch?
I'm going to go back to where this all started with that dark green turn signal wire and troubleshoot from there. In the meantime, I'm open to suggestions. Have any of you experienced this kind of gremlin? At this point, I'm grasping at straws. PLEASE HELP!!!
John
John
