engine swap 350 rocket
MWA
129
MCDonough,GA
I have an 83 cutlass and I need some help! I want to take out the V-6 and put in a 350 rocket can anybody help me? Will the swap be hard to do?I need some direction. Is this a good choice?
Get the 307 Olds frame mounts and the 350 bolts in. The 350 is externally identical to the 307, so use the 307 brackets, manifolds, etc.
Get frame motor mounts from 307 car, get radiator and shroud and rad top cover from 78-88 cutlass 307 or 260. But battery on other side and fuel lines. Take th200 trans out and get TH350 bop bolt pattern. Also get a 1968-1972 Rocket they are the best motors. Also get an A4 aluminum intake from a 1980-84 307.
