Engine swap question?
Joel86Cutlass
Jan 14, 2009
61
12
8
Pennsylvania
www.cardomain.com
Hey guys any help you can give me with this, or if this has been covered before point me in the right direction. I have a Pontiac 455 out of a late 60's car not sure what and want to put it in a 84' Cutlass Supreme. Any tips on motor mounts, headers, etc. Thank you for any help.
hit up blake442 on this site he should be able to help you out as he has done this swap
Pretty sure Blake did the Olds 455 swap, he is asking about Pontiac.
Yup, I went Olds 455... 8)
The Poncho motor will work, you'll need a set of 301 motor mounts to drop it in.
Headers I'm not sure, I think shotgun would be able to fill in the blanks better than myself.
Doober said:
Questions would still be valid though 😉
Not really. The Pontiac and Olds 455 motors are completely different. The only things they have in common are the bellhousing bolt pattern and the distributor.
PM sent. 😀
I understand you have the motor, but putting in a small block chevy will make you happier unless you spend some bucks on that Poncho mill. The rope rear main seal is a JOKE, the conversion kit is expensive. The heads are terrible, flow, port design, combustion chamber, they make decent boat anchors though.
