ok...I start from the begining. Fresh 355. from the start it was blowing oil out of the timing cover onto the front of the intake and puddeling on the top exterior of the intake. at the time i only had i breather in one valve cover and a oil cap in the other. i then removed the oil cap and installed another breather, but the blowing oil concern kept happening. i had run the car pretty hard and found that the rear main seal was leaking alot. with the engine running and rear main leaking (dripping) i pulled out the engine dipstick, and both breathers off and the leak stops like i turned off a switch. i then added a vented breather catch can on the fire wall, removed the baffles in the valve covers and added a pcv valve. this solved the concern of blowing oil from the front of the engine, but now when i run the car hard, it blows heavy (looks like a fog machine!!!!!) white/blue smoke from the exhaust and still pushes the dip stick out of the tube. the engine only has 1000-1500 miles on it. what else could be the problem???? just as a note- the engine does have high oil pressure. 60-70 psi cold idle, 20-40 hot idle, 60 psi at 2000 rpm cruise hot, pegs the gauge at 100 psi 3500-4000 and above!!!
