exhaust kit question
6,134
13,334
where could i buy a muffler or have one made, that has an inlet on one side, and on that same side has an outlet, and on the opposite side has an outlet? that way i can make a dual out let exhaust without differing much from a conventional single outlet exhaust. its kind of a whacky setup, but if i can find it, i can make my idea work. what i really want is a nice, low rumble, medium loudness exhaust, with true duals or dual outlet from the muffler.
3rd generation Camaro muffler. I had that setup on my car way back years ago when it still had a V 6 in it. I worked at a muffler shop back then so I was able to try all kinds of stuff.
If I remember right, it was mounted behind the rear end. Between the rear end and the gas tank. Just like an old cross flow setup on some 2nd generation Camaros and Fire Birds. Any reputable muffler shop should be able to do this.
Flowmaster makes one....its not stainless, its stamped. I'll try to find the part number for it.
Flowmaster 80 series. I had one on my Regal 4 years ago when I was 18. Sounded great. When I first put it on, my catalytic converter was still muffling my exhaust down to stock level so you may have to address that. I live in an area where they're not necessary so I just took mine off but my original idea was to replace it with a high flow cat.
http://www.flowmastermufflers.com/shop/ ... 34_156_231
Sounds like a basic cat back muffler to me. Should be able to find them everywhere
Yep flowmaster 80 series its what i have on my Camaro but i run a 3" Y pipe.
