Hi,
I've got an '84 2dr SBC car. It has dual exhaust on it now w/ headers that needs replacing badly.
The car isn't a hotrod and sits very low, my priorities for this exhaust system are as follows;
1. Clearance
2. Sound (No drone)
3. Efficiency
What i'm thinking is the following, could anyone offer any input or suggestions?
Shorty headers to an OEM style Y-pipe, pass the crossmember through the OEM notch Use a single in, dual out muffler tucked in the OEM location and running two pipes straight back and exiting under the bumper.
Does anyone have a similar configuration? What dimension of muffler did you use? Any advice? An obvious answer it to use an OEM system, but I'd like to increase flow a bit as there's a mild motor in the works, also a nicer tone would be a big +.
Thanks!
Andre
1. Clearance
2. Sound (No drone)
3. Efficiency
Thanks!
Andre
