Okay this is driving me crazy. I have an 87 Cutlass with a SBC vin R Vortec 350 freshly rebuilt. 9.5:1 compression, Edelbrock 2209 cam(212/222 @ .050"), edel brock 7801 chain and gears, Thunder series AVS 650 carb w/spacer,RPM air gap intake, GM HEI distributor for a 77 camaro, accel shorty plugs .040 gap, Holley blue fuel pump, Hedman shorty headers, March serpentine conv, and 700R4 Trans. It's running extremely rich, and if I step on the gas to quickly it will stumble, stall, and or backfire through the intake. When I check the plugs after running it they're black. I have set the fuel pressure anywhere from 3.5lbs to 5.5lbs. with no change. I've set the timing from 12 to 16 BTDC. The idle mixture screws can be turned all the way lean and the car will still run. I've tried hooking up the vacuum advance from the dist. to both ported and manifold vacuum with no change. I checked to make sure the correct jets, and metering rods were installed from the factory. I've tried several step up springs, and then I tried installing my friends Quick Fuel 750 Carb. No change at all. I removed the timing cover to check the position of the crank sprocket. It was not at the 0 degree setting, so I switched it to 0. No change. I don't think it's a valve lash/spring problem because every plug is black. Could it be something with the HEI distributor? Wrong one for this motor, Or some other ignition problem? Ignition module under the cap? PLEASE HELP BEFORE I BURN THIS CAR TO THE GROUND!
