every time i crank my car, the dog on smog pump squells! then after it heats up it stop. what do i need to do to remove the factory smog pump off of my completely stock 85' olds 307? and what do i need to plug in the lines...?
if it's tensioned properly it shouldn't make any noise.88 hurst olds said:Not sure what you mean by dog or squeal...
How about just replacing the belt...![]()
RITTER said:You will also have to measure your pulley system for a new belt![]()
FE3X CLONE said:you can remove the AIR manifolds and put plugs in their the place.
