gk666 said:do you go to any meets.... your BOUND to find someone at one who can
82Calais said:I watched it on TV once. they used a wood baseball bat in the wheelwell against the tire & drove the car ahead. being the bat is tapered you have some control on how much you roll the lip. It looked easy. I've never tried it. Maybe a vid on you tube?
bat trick is a poor mans fender rolling machine and doing it that way will run you a risk of damage......any rim/wheel shop in your area should have the REAL fender rolling machine,they also sell them on ebay85montanezSS said:82Calais said:I watched it on TV once. they used a wood baseball bat in the wheelwell against the tire & drove the car ahead. being the bat is tapered you have some control on how much you roll the lip. It looked easy. I've never tried it. Maybe a vid on you tube?
yeah thanks ill look for one but i rather have someone who has done it plenty of times to do it but thanks anyways.
87LS-WITH-AN-LS said:bat trick is a poor mans fender rolling machine and doing it that way will run you a risk of damage......any rim/wheel shop in your area should have the REAL fender rolling machine,they also sell them on ebay85montanezSS said:82Calais said:I watched it on TV once. they used a wood baseball bat in the wheelwell against the tire & drove the car ahead. being the bat is tapered you have some control on how much you roll the lip. It looked easy. I've never tried it. Maybe a vid on you tube?
