The fuel/air dwell mixture is stuck at over 50 degrees not moving. I tried causing a vacuum leak by disconnecting the PCV valve which did drop the dwell by 20 degrees, indicating the O2 sensor is operating. This seems to be pointing to an over rich condition, I don't what would cause this as the motor was running fine before with correct dwell and this problem came out without warning.
A couple years ago my motor was running lean, turned out to be a vacuum leak which I fixed. Then I set the dwell to the 30-35 degree range, I remember when I took the air cleaner lid off the dwell would go rich. Now when I take the lid off there is no change in dwell.
