FlowTech headers questions
Doug213xrj
1,529
131
West Michigan
I`m look at Flowtech # 1104FLT Ceramic Coated headers for my 78 El Camino and I have a few questions. Hows the fit and hows the Ceramic Coating look after a few years ? Can the big truck style oil filter be used and is the big factory starter easy to remove ? how do they fit around the upper A arm ? any advice would be appreciated.
Thanks Doug
if those are the afterburner ones you're looking at, they wouldn't work with my jegster trans crossmember... the outlets are close to the transmission, and end too close to the crossmember to make a non-restrictive bend on the driver's side... other than that, they fit in nicely and clear the larger oil filter.
