i believe I have a problem. On my 9" housing that I got, the axle tubes are the same length on both sides of the differential housing. This means the yoke is offset to the passenger side slightly. The 7.5" that came out was the same way too. But most of the gbody 9's that I see the driver side tube is slightly shorter. Am I up sh*t creek or can I weld the brackets on (with proper angle of coarse) and run the slight yoke offset? I'm about to pull my hair out.
