I need a new front tire and a alignment so I just going to replace both fronts to a bigger size. I have 14 up front with 15 out back on 255/70/15. Question is what size fronts would go good with those rear tires. Fronts are currently 235/60. Should I replace the rears to some wide but shorter tires and make the fronts taller since they are 14"?
That is a tall tire on a gbody. 29" I run them on the back of a 442 with a 26.1" 235/60/15 up front because of my gear, shift points and power band. But it looks a little too tall for my tastes on that car. It would look better if I could take about an inch out of my rear springs but then may rub regardless of spaceing. They would probably look ok with a 225/70/14 26.5" tall.
If you decide to buy all four you might consider 215/70/14 25.9" with 255/60/15 27.0".
