Wiring for the sender unit to the dash is old and need replacing.Today I went out to start the wagon been sitting up about 2wks I noticed when it was running the fuel gauge had went way pa full and now it’s stuck there, any idea what’s going on has new sending unit thanks
Gauge seems to be good. Now to figure out if your ground wire has a good ground, and the connection to the sender (usually a round push on connector) is nice and tight. Pull the pink wire sender connection off and ground it if you haven't already and make sure the entire wire is still good.when the pink wire going to the fuel gauge is grounded, the gauge goes to empty
