G-body coil springs
jlat
256
61
hello G boys and girls; Beside the differant spring rates are all springs interchangable?
IBBY
IBBY
For the most part...all gbody springs fit all other gbodys....if thats what your asking
hello; Yes, that was the question and I thought that. But if I was buying new springs I'm getting ones made for my car rather than yes they will fit. I've been looking around.
thanks
Now if you get lowered springs does that make the frame lower to the ground or just lower the body to the frame?
IBBY
thanks
IBBY
Lmao. The body is bolted to the frame so it makes both lower to the ground. :rofl:
thanks
IBBY
Why are you getting some made? What are your goals? You can buy them new for cheap so check around before paying someone to "make" them. G body springs are interchangeable but will have very different spring rates. This will effect your ride height and quality.
hello people; I'm glad I made someone laugh a bit. I have a 86 T and my goals are just improved handing for the car. I have front GSCA coils I got years ago and progressive rear coils riding on 16x 8 rims.
I'm getting a little sick of looking at info on springs so I'm going for a set of rears from GSCA also. They are made for the car. $155.00 to my door. They'll match the fronts and that's good. I was interested in some lowered coilss but with the age of the fronts there probably lower anyway.
we'll see what happens and they won't be put on till spring.
IBBY
