I can't find my Hazard Flasher. I found my Turn Signal Flasher on the Fuse Panel. But no dice on the Hazard. It use to work, so the flasher has to be somewhere. I looked at the box where the horn relay is, on by the Headlight switch. I didnt see nothing.
My cutlass is an 85 and the hazard flasher is located to the back of the dash just to theright of the steering column. The easiest way for me to change it was to remove the radio and look up.
