G body LSX turbo manifolds
IT_SS
6
What are the g body LSX folks using for turbo manifolds? Will reversed truck manifolds work?
see if you can get some 2010+ camaro take offs. im pretty sure but not positive that they would work flipped backwards. the outlet is all the way under the last primary, kinda angled away from the engine too. might even be able to use an edlebrock shorty header for the same car flipped around.
http://www.norotors.com/index.php?topic=331.0 this website link has a picture of them mounted on an engine (2nd pic down). hope this helps!
reversed truck manifolds, or s10 headers on one side and a custom log mani on the turbo side, the log mani would go back around the back/underneath the motor to connect up with the turbo side, ill see if I have some pics
this is how someone did theirs in an s10 (which will be similar)
ls1 swap headers for an s10 should work also, thats used on the driver side...
I believe a reversed truck mani was modified on the pass side and then a piping made to connect it all, this particular setup was for sale at one point
