I will be changing the power train in my Monte and since I will be going Fuel Injected wondered what tanks have been put on a Monte. I have a 94 Caprice and roughly the cars are equal on width and think a tank from a Caprice might fit.
I wondered if anyone has tried the change. A benefit is of course in tank pump for FI and also more fuel (22 gals I thnk). I don't like the idea of a fuel cell in the trunk and the GN tank is $157 shipped but then I need the fuel pump assembly and I am told they are not cheap...
Bottom line is I have a tank from a 94 Caprice so it will only cost a pump and straps to install if it will fit.
I am gathering the parts for the drivetrain swap and will start the change over in the Spring. I have a 4 bolt Vortec block (given to me--but has a spun main so must be align bored), I will buy a 4L80E, convertor and fabricate a twin turbo setup.
It will take longer to save and get the parts than it will to build the setup...I don't want to borrow for the parts and it will likely cost ~8000 so Spring is probably realistic.
Thanks
Thanks
