Thanks everyone.
Some stat on the car. I just pulled the stock motor/trans and put in the built motor and built trans that came out of my wrecked 86 GN.
The motor is .030 over, 210/210 Comps roller cam, ported/polished stock heads, T&D 1.55 roller rockers, 50lb inj, stretch stock location intercooler. Trans has a 3000 stall 10" Pats Performance Converter, sonnax servo, extra clutches and a Trans Go shift kit.
Rear suspension has Moog springs, KYB shocks, UMI tubular control arms and an ATR sway bar.
Front is the same, Moog springs, KYB shocks and 34mm hollow sway bar from an F body.
Wheels are CenterLine Retros 17 x 9.5 in the rear and 17 x 8 in the front with Kumho Ecsta MX's 275/40 and 245/45.
Just got the methanol injection installed and filled and slowly tuning and turning the boost up.
