Tried doing a forum search for "200-4R" and nothing came up. Hard to believe there aren't any other posts about them, so please forgive me if there are, at least I gave the search bar a shot. :lol:
I'm buying a 200-4R either on E-Bay or Craigslist and going to rebuild it for my Buick with a California Performance Transmissions "Super" rebuild kit, and maybe their Deep Cast Aluminum Pan (mostly because it has a drain plug, and holds 2 extra quarts of oil). I might buy some other parts as well if money allows, but the Pontiac motor I plan on rebuilding and swapping in will probably be around 400 horsepower, 450 ft-lbs torque. (455 with 98cc D-Port heads, Edelbrock intake, Q-Jet, approx. 9.2:1 static compression)
Does anybody have any experience or advice with these as far as putting one in place of a TH350? What else will I need to make it work? I know it SHOULD go right in since it's the same size, and has basically the same mounting points as a short tail TH350 which is in my Buick right now, but will I need to do anything to the cross-member, shift linkage, shifter, instrument cluster? Anybody know the best place to get the little stuff? It's the fine details that most newbies like me overlook, so I figure why not ask. Also, are there any other parts aside from the rebuild kit that CPT offers that you would suggest as being "must haves" or are there any other companies that you would suggest over CPT?
