glove box won't open
malibujustin
333
424
51
Question...1980 malibu...can't get glove box to open. The key fits and turns knob but it will not open. Don't want to break it. Any ideas? Thanks
Tried a Fonzie knock? Seriously...
Yea I tried the fonzie knock...tried it a few times.
My guess is you got some paper,napkins,etc. closed in the latch not allowing it to open. Can you get a knife blade in to move stuff around?
MalibuJusten, mine did that new! I used a channel lock pliers, put the Big twist on it. And then purchased a new latch-lock. Be careful not to scratch the door like I did. In my case the internal rack (latch-lock) wasn't cast very well. Yours could be worn out or like Andebe said you may have something stuck between the latch & catch. Good luck Ole' Bob.
My 87 Monte Carlo does that if the box is slammed shut or hit hard while closed. Gently shutting it causes no issue. I have not yet figured out why.
My GP's glove box lock cylinder it totally fubared. The only way I can open the door is with a thin, narrow flat screwdriver. I obviously need to replace the entire cylinder assembly. Where did you get yours?
I haven't had the car but a few weeks. But I will try to "jimmy" it open. Then check latch.
