I Think this should be a sticky:alot of people on this board ond others always have questions about the gm 7.5.What will fit?What Gears?GM has 2 different splines:26 and 28.28 Was on the 88 or 89 and up years.S-10s are a common swap from junkyards because of the gears and most have posi.A Big misconception is the monte ss all have posi.What can a 7.5 hold up to?Each his own.Some say they have run big-blocks with no problem.Some say they have run 450 hp On a factory rear.Personally I think its only as good as the builder-Throw a motor together without a mic,why did it blow?My point being if your on a limited budget why couldn't the 7.5 work if properly done?my 2 pennys worth
