Let me start by saying I'm no electrician.
For about the last 4-5 days that I've used the car, the battery (charge) lamp in the wagon has been VERY dimly lit while running.
My understanding of the lamp's operation is that if the alternator output and the battery voltage difference are outside the designed operational range, the lamp will illuminate.
I have checked all the connections, they are clean.
I checked the alternator output, it is 14.8 volts at the "bat" terminal
I have a remote start relay, voltage running is 14.8 where it meets the cable to the battery.
I checked the voltage across the battery while running/charging...14.8 volts
Battery voltage engine off 12.9 volts
In the daytime, you can't even see it, but overcast or dark outside, it is glowing dimly So far, no issues with starting, but really don't want to find out the hard way.
What am I missing?
What am I missing?
