grand national 8.5"????
84_ttops said:
hey wondering if the grand national 8.5" rear end is same width as the g body 7.5" rear end? for some reason i can find a straight answer
Yes it is the same width!!!!! If you switch from the 7.5 to the 8.5 you will need to get your driveshaft cut one ionce...The 8.5 pumpkin is an inch bigger 🙂
I would think so, if your talking about the length from hub to hub.
JBreu said:
Yes it is the same width!!!!! If you switch from the 7.5 to the 8.5 you will need to get your driveshaft cut one inch...The 8.5 pumpkin is an inch bigger 🙂
