Grand National rearend swap question
Tuggy24g
658
16
35
Newtown PA
www.myspace.com
Hello I have a guy who is going to sell me a stock 8.5 rearend from a GN. Well it has stock posi and 3.42 gears. Anywhoo what will I need to do to have the rearend handle 550HP. I know I will need a c clip eliminator. Other then that I am not sure
thanks
Brad
You'll need to shorten your driveshaft 1" for starters.
As far as internals, an upgraded carrier is a good idea, but it'll handle the power.
Are you running slicks on the track? If not it will be more than good enough the way it is.
Then it should be good to go as is.
Then the 8.5 should be good as is.
