will attempt to gravity bleed my brake system on the cutlass. i read this the easiest way to bleed your. as part of the restoration process i removed the brake booster with master cylinder still attached. now reinstalled the brakes needs bleeding,this is my first time trying to bleed brakes. i have watch a couple video on YouTube on gravity bleeding, not sure if the car has to sit level when doing this are does it have to be a little higher on the end you are working on (front --- back) so if anyone on the form has ever done this and their is anything i need to be careful of when attempt this i would appreciate your comments..... installed my new american eagle aluminum radiator rated 600 hp on the 455 it's keeping it a lot cooler. it did get up to about 195+degrees but under 200 while sit idling (as if stuck in traffic) when press on the throttle it did start to drop. i think will replace the thermostat....also changed the lower hose it's not collapsing like before...i'm happy one less problem
