I need to replace the heater core on my Cutlass. One of the pipes broke. It's got A/C and I need to know what would be the easiest way to remove it and throw a new one back in.
We're not exactly sure if that is the cause of all the antifreeze going everywhere near the left back corner of the engine, but it's broken now and it might not be the main issue, but it needs to be fixed before we can find the real issue. It doesn't look like the antifreeze is coming from the head or anywhere down that low, it looks like it might be coming from a hose going to/from the heater core, but we need to get some light up in there to fully check that out. Anyone have any other suggestions?
It happened this morning (which was pretty cold, probably a bit below freezing) and I turned on the defrost and it was barely working. I then smelled kind of a light burning smell then once I got where I was going I noticed a strong stream of smoke pouring from the passenger side of the engine. I didn't notice any antifreeze all over like it is now. I went home (not far away) as quickly as I could after the day was over and it just kept constantly pouring smoke out. I got home and popped the hood and antifreeze was all over everything on the left side of the engine.
Thanks. 😀
Thanks. 😀
