help!!! cutlass need medical attention
Cyborg-Elite
6
ok listen>> i have a 1988 olds cutlass supreme 5.0.. and i bought the car 3 years ago, ive changed my thermostat, water pump and power steering pump..and alternator..and rad cap
my temp is at 200 when im driving..and 190 at idle.. dont know if this is good or not..and when im driving and i smash the gas pedel it putters and i hear this like dugga dugga dugga noise wen im driving sometimes.. and after a while my steering feels tight when my car reaches 205 in temp... and theres a random vaccum hose from te front of the intake manifold thats been plugged and to top it off i have heaat blowing on my feet..thank you in advance
If youre running a 195* thermostat those are pretty normal engine temps. Its designed to keep the temps around 195. As far as the noise maybe be a little more specific? The power steering sounds low or like theres air in the system. As far as the heat goes, im assuming your car has an ac setup as the majority did. Check the vacuum lines and cable on the dash controls. It sounds like the doors arent working properly.
The best resource for all these problems, is a factory service manual. They are available for around $75 iirc, and are better than guessing when you have problems.
