Those A-arms look like the one's that Robert Adams used to sell back in the day. I don't think he sells the kit anymore since all the links I've found are dead. Just to add to the confusion or to prevent you from falling to some gotchas...chances are with those A-arms, you have A/
B-body spindles or possibly F-body spindles which means the rotor diameter could be 12" or 11" depending which spindle you have. The Chrysler screw in ball joint does have a different taper to them so the GM spindle is reamed to accept so if someone decided to change out those UB machine arms to say GW or Hotchkis that upper balljoint taper would need to be addressed. Calipers, brake pads, bearings...all the replacement wear parts would be specific to the A/B/F-body vehicle and not the G-body.
Glad JeffD still hosts this page.
Robert Adam's Kit on an SDime
