My guesses using my electrical service manuals.
Pic 1. The there wire connector with the dark blue, gray/black stripe, gray wires is cruise control wires from the multi-function lever. As noted the turn signal fasher. That last connector is looking like the C105 connector which is as noted for cornering lights & plugs into the steering column connector for the turn signal switch.
Pic 2. The one with the brown & 2 gray wires is the cruise control brake switch connector. The other one with the orange & white wires is the brake switch connector for the brake lights.
Pic 3. This is the connector for the rear window deforgger wire that runs to the glass.
Pic 4. That is anothr connector for the cruise control, connects the circuits between the control module & control servo, listed as C372. As alredy noted.
Pic 5. That one with the heavy pink wire looks to be the power window fuse box connector. The tan wire looks to be for the parking brake switch. Both as already noted.
You might have to remember where you source the harnesses from unless they came with the car. It seems like you have '84-'85 wiring in the car.
