help Stuck removing wheel wells
tbird1986
115
Indianapolis
hey in my 86 cutlass i am in the process of removing the front inner fenders got everything relocated and cleaned up went to remove them tonight and everything was going great until the last two 10mm bolts on the back side down at the back of fender.. does any one kno how I can remove these two like how to reach them? thanks
Im in the opposite situation I cant remember how to get mine back in properly......anybody do a write up with pics.....please. Did alot of modifications to this thing beyond stock but something stupid like this has me stuck
Which side, or is it both?
If it's the driver side, remove the windsheild wiper motor to get better access if you haven't already, and once you can feel the bolt, you should be able to get a socket and a long extention on it.
These cars were assembled at the factory with the wheel wells already on the fenders when the front clips were installed.
When you're putting yours back together, just do what I did, and say **** it and leave those bolts out.
yea it is drivers side and Ill work on getn the motor off when its not so rainy haha thanks, If i had a camera I would do a write up
outsider_27 said:
tbird1986 said:
is the wiper motor just held on my 3 bolts?
yes
Don't forget the bolt that connects it to the wiper linkage.
But you should be able to see that
