HELP WITH INTAKE!!!!!!!!!!!!!!!!!
two90west
227
16
chicago
I HAVE A 1986 OLDSMOBILE 307 ENGINE WITH 7A CYLINDER HEADS, COULD SOME ONE GIVE ME THE CORRECT PART NUMBER FOR THE EDELBROCK INTAKE THnks!!!!!!!!!!!!!!!!!!!!!!!!!!
ONCE AGAIN THANKS BILL AND ONE MORE QUESTION, I WANTED TO GET A 5OO CFM CARB BECAUSE ITS A SMALL V8, WHICH ONE FROM EDELBROCK DO YO SUGGEST!!!!!!!!!!!!!!!!!
I suggest you seriously consider changing heads first...the carb and intake wont do much good without better heads because the 7A heads have smaller ports. If you decide to go with the 7A heads and you are gonna change out carbs, you need to remember that your engine will be running off the computer. If you dont intend to do away with the computer, I would stick with the stock carb set up. Have the carb rebuilt and it should be fine. If you do go with a new carb, this one will work fine....http://www.summitracing.com/parts/EDL-1406/....500 cfm is hard to come by and probably more expensive.
