ok i have a 85 cutlass supreme with a 307 in it with 80,000 miles on it, with a 200r4 trans. do you think a 350 turbo tran will fit on my 307 or not. thank you ....
youngwhip said:ok i have a 85 cutlass supreme with a 307 in it with 80,000 miles on it, with a 200r4 trans. do you think a 350 turbo tran will fit on my 307 or not. thank you ....
outsider_27 said:If I were you I'd keep the 2004R, if you switch you loose the overdrive and have to change crossmembers and shifter indicators.
custom442 said:outsider_27 said:If I were you I'd keep the 2004R, if you switch you loose the overdrive and have to change crossmembers and shifter indicators.
x2, keep the overdrive. Unless you want the th350 for specific gear ratios.
