Help with suspension.
Arod6692
n00b
Apr 16, 2013
4
Hey guys I got a 87 Gnx clone with a ford 9in with 456 gears qa1 double adjustable shocks a airbag in the right spring and adjustable upper and lower control arms with 1 in belltech lowering springs and mt street radials. I'm having a hard time hooking up. I'm looking to but qa1 double adjustable coil overs in the front and switching up my springs in the rear. I was wondering what springs you guys were running at what rate. Also about where I should adjust my shocks to. Thanks.
softer in rear can help if your blowing your tires off... the car needs to squat to launch- too stiff suspension and it just spins. also what PSi are you running in your tires? if you run them at 35 psi, you will roast them... I used to run street tires at 15-18 psi and I got better traction...
