I need help once again.. I got my megashifter in today and was wondering if I need to take the transmission out to install it.?
kiefer84cutty said:No I don't have one.. I'm installing one cuz my linkage cable hits the headers when I shift down to first?
Hmmm I must have got really lucky because mine went in very easy with the trans in. I only had a small problem with reaching the right rear mounting bolt from underneath to tighten the nut. Other than that it was a walk in the park.Qdub24 said:kiefer84cutty said:No I don't have one.. I'm installing one cuz my linkage cable hits the headers when I shift down to first?
I had that same problem. My dad installed mine w/o dropping the trans, but he said if he had to do it again he would've just dropped the trans. You've got to drill 5 holes. 4 holes to mount the shifter and 1 for the shift cable to go through. If you don't drop the trans, you have to be very careful not to drill into the trans itself. The 4 bolts that hold the shifter to the floor are a pain to get at to tighten it down as well with the trans still mounted. I had to remove my shifter by myself once w/o dropping the trans, so I definitely no how hard those 4 bolts are to get to.
