Helpp 87 cutlass
Tyler
14
4
26
Hi i have a 1987 cutlass when i turn on my headlights my radio display goes out and my cluster backlight doesnt come on anyone have this issue before?
Sounds like a ground wire issue. There is a few wires screwed to the bottom of the dash on the drivers side, check those for any damage or corrosion.
Sounds like a ground wire issue. There is a few wires screwed to the bottom of i of the dash on the drivers side, check those for any damage or corrosion.
I had a similar issue yes check for grounds. Or make sure the right peanut bulbs are installed on the cluster
