So, I've got a couple of sets of NOS belts, but I also happen to have some factory-installed belts for my 85 442.
I hesitated to use aftermarket belts, as they're just not marked up properly.
I checked into those aftermarket reproduction GM belts, but while they look pretty cool, they're pretty pricey as well. Plus, nobody will tell me where they got them made, and they don't have correct codes/part numbers. Once again, I gotta make my own. So I got 4 part number stamps made, as well as the "dot code" stamps, whatever those are. I tried to find out for sure, but nobody is coming off that info or they don't know.
So here's my latest test piece. The OEM belt (A.I.R. pump) is on the bottom, and I replicated a stamp best I could. The top belt is an old, used aftermarket belt I took off the 84 simply used for testing the stamps. My bet is, although not exactly like original, it can pass muster at any judging because 1)it's the correct part number, and 2) unless you poke it right up next to a GM belt, I'm thinking it won't be easy to tell. Besides, reproduction stuff is fine if it LOOKS like the original part. I may go back and redo the stamps more exact, but then again, who's really going to notice?
I'm happy with how it turned out. Not exact, but I'm happy enough not to nit-pick it to death. I got several "made in USA" belts that I'm going to use to make my repros. Mostly Dayco.
