hookups
JasonL
105
4
Hello, just pulled out the stock motor in my 80 Monte carlo. I am putting a 355 in there and taking out the canistor and air pump. I am installing the AC and Heat again. There is a valve on top of the motor that the heat hose from the heater core went to.....Do I need this? All the plastic lines off the heat ball, do they just get hooked up to a vacuum source? Thanks Jason
The hose goes to the heater valve. You can remove it but it'll circulate hot water all the time. I'm not sure what you mean by "heat ball".
