It will also depend on your rear suspension. If you have 25 year old rubber bushings that are cracked and dry rotted, expect some flex to allow the wheels to touch the frame under hard cornering. If, however, you have upgraded to a more solid rear suspension like spherical bearing LCA's you could probably get away with more.
