Anytime I'm working on one of my cars, I always have a bottle of anti-seize handy, and that's what I use on brake cables. Step on the brake to expose as much bare cable as possible, then smear a thin coat along a few inches of the cable that's normally retracted into the shielding. Also spread a little bit on any of the guides as well as the adjuster threads.NofoBuick said:How do I (or can I) grease my parking brake cable and the steering components? I see the zerk fittings on the pit man arm and other steering parts. I can just hook a grease gun up and go right? Thanks for all the help.
rustyroger said:Using a grease gun is a much neglected part of maintenance, especially as fewer cars have grease points and mechanics are unfamiliar with them on older cars.
I grease my car a few times every year, particularly if it has stood for any length of time. Every grease nipple (zerk fitting?) gets attended to.
I have the car off the ground with the steering turned one way and give all the joints a couple of pumps, then turn the steering the other way and do it again to make sure grease has got all round the joints. Before I start I also check the joints for play, fresh grease can hide a bit of wear.
When I first worked in a repair shop (39 years ago, God I feel old!) I had to grease up an old Humber car belonging to a customer who bought the car new in the early '50s. It had grease points everywhere, suspension joints front and rear, driveshaft, parking brake cable and linkage, speedo cable, door hinges, even the water pump - I had to remove a plug, screw in a nipple, pump in ONE stroke only, then replace the plug - no wonder apprentices were called grease monkeys!.
Grease points are becoming a thing of the past, brake cables are prelubed at the factory nowadays, I'm not sure this a good thing, I have replaced plenty of frozen parking brake cables but that old Humber never needed one.
Roger.
Peter said:rustyroger said:Using a grease gun is a much neglected part of maintenance, especially as fewer cars have grease points and mechanics are unfamiliar with them on older cars.
Roger.
its not that mechanics these days dont know about grease fittings. its the 15 dollar oil changes and the expectations of an oil change being pumped out in 5 minutes. its not the mechanics, its the system
