Here's the deal. I have an after market A/C setup that I am hooking up to my 455. All the wiring diagrams call for a trinary switch if your using electric fans, otherwise you use a binary switch. The trinary switch engages the electric fan(s) if the system pressure gets too high.
From the get go I planned on installing a trinary switch since I have electric fans but do I really need to?
My Accel Thruster EFI controls both my electric fans as well as the WOT A/C clutch cut out. It is also setup to turn the fans on anytime the A/C is turned on. If this is the case, then wouldn't I be okay with just a binary switch in the A/C system?
Thanks,
Thanks,
