HVAC Box
fraido2002
254
2
40
Mid Michigan
For those of you who have pulled your ac/heater box, I purchased a new gasket from mikesmontes. What type of sealant if any do i need to apply to it. Do I need to put a bead all the way around before i put the gasket on, or do I put some sort of seam sealer around the outside after I put it back together(which is what it looked like the factory did.) I really don't want to go through all this work and have my firewall leak. Any tips/advice would be helpful.
Blake442 said:
I'm a big fan of 3M Strip-Calk.
X2 on the Strip caulk..
For the outside edge, use 3M professional grade seam sealer....keep your finger wet as you smooth it along and Itll look killer!
